- 25 Aug 2013
I'm about to overclock my 3960x and would like to use speedstep and voltage offset to help keep my idle power and temps down. I have an x79 Sabertooth motherboard and 8gb of DDR3 2133MHz RAM.
Can I ask if anyone has experience with offsetting even on different CPUs and if they have found that it causes instability compared to constant voltage at all?
As I understand the voltage offset function essentially sets a voltage that the MoBo deems as correct for your clock speed and then you can adjust it using the offset value. Is this correct?
The advantage essentially being that your voltage lowers when speedstep lowers your clock speed, whereas with manual voltage input it is set and doesn't ever change?
For full disclosure I understand I will have to tinker with clock speeds and voltage offsets to get it right for my CPU
