ASUS X550C Notebook Optical drive replacement
22 Mar 2007
My google-fu has deserted me while trying to find a replacement drive for the above Notebook.
I'm fixing it for a workmate who's wife dropped it with the drive drawer open and broke it, but finding the part is proving very difficult :D
Make: Asus
Model: X550cA-XX766H
Part: Super Multi DVD Rewriter
Model: GU17N
S/N: 332GU71NO053195
I've emailed Asus directly asking for help sourcing a part as it's an easy fix, but getting the part is the problem.
If anyone's Google-fu is working or can find it somewhere (preferably UK), please let me know :D
The bezel seems fine and the eject button works ok, the only thing that threw me was the casing of the drive.
Same as below.
You need to measure the height of the drive to determine which one you need, then eject the tray using a paper clip and release the three plastic clips holding the bezel on. I forgot to mention you will also need to move any support/fixing brackets to the replacement drive, it looks like you have a bracket on the rear that is probably held on by two screws.
EDIT: Actually going by the part number its a 9.5mm drive so its the slimmer type you need, this one should do http://www.overclockers.co.uk/showproduct.php?prodid=CD-157-SA&groupid=701&catid=10
