Anyone running HWiNFO64 v5.22 with Asus x99-A mobo or other Asus x99 mobo open HWiNFO.
Scroll down to your mobo temps/voltages look at Temps, mine shows TEMP3 as 103/100/103/103 anyone else having that issue.
A few online have having reported the same issue its either buggy HWiNFO64 or Bios, faulty sensor.
PC is working fine no problems with temps at all gaming BF4, Dirt or benchmarks all ok, no bsod's or crashing to desk top.
UPDATE-
So after doing a bit online research came across this see blow-
Extremely high temps on X99-A Asus based PC in hwinfo forum--> http://www.hwinfo.com/forum/Thread-Extremely-high-temps-on-X99-A-Asus-based-PC
vraev-OP
The CPU [#0} is reporting temps of 50, 36 and 29 while the nuvoton sensors are reporting 110 and so on. Please someone take a look and tell me if everything is ok? It was an expensive build. I don't want to fry it.
BTW..using a corsair H60 water cooling loop to cool the CPU..but fans for everything else. The pump is plugged into the CPU fan, and fan of the radiator plugged into a chasis fan.
Can someone please explain...which is actual CPU temp? Which is actual GPU temp? there seem to be two for everything.
Martin HWiNFO Author-Reply
I believe everything is OK. The problematic temperatures Temp3-5 are invalid and most probably come from not connected sensors. I suggest to ignore them.
The GPU displays 2 temperatures, but they are the same, just use different approaches to read the temperature. You can rely on either of them.
As for CPU temperature, either the Core Max or CPU Package are the most important values determining internal CPU temperature.
vraev-OP
