- 4 Aug 2015
After two months of having a box full of components for a new build lying around I eventually got around to building my system over the weekend. Luckily I had no defective parts, but I have a few questions.
The core spec of the system is:
Asus X99-S (as the tile suggests)
Intel i7-5820K
Phanteks PH-TC14pe Cooler
32GB Corsair Vengeance LPX DDR4-2666Mhz Ram
Phanteks Enthoo Luxe Case
Phanteks PH-F140SP fans (x4)
Palit GTX980ti Super Jetstream
So I assembled the system and I must admit its been a long time since I built my own computer, the last was a 386/486, so there were lots of new things to take on. Everything went together OK although the CPU cooler took two attempts, but there were a few things that I'm not sure about.
Memory - although the memory is rated at 2666Mhz, the BIOS is showing it as 2133Mhz. The XMP profiles give me an option of changing to 2667Mhz (profile 1) and a higher speed (profile 2) which I can't remember what it was. If I change to profile 1 or 2 I sometimes get a "overclock failed" message on boot. Anyway I don't understand why the default clock speed for the memory is not 2666Mhz. Is there a switch on the board I need to change? In the manual there are three switches additional switches which I'm not sure about :
"TPU" and by default is off, I can set this to "Enabled - CPU Ratio Boost" or "Enabled CPU BCLK & Ratio Boost"
"EPU" and by default is off
"EZ XMP" and by default is off.
What do I do with these, I assume these are to enable overclocking, but I'm not sure.
FANS - So my case has a built in PWM hub which before I started the standard case fans were all connected to this (2 x PH-FP140SP 1 in roof and 1 at back & 1 x PH-F200SP in the front). I bought some additional fans, the same type as the ones already installed to install in the roof of the case and one in the bottom. These I have also connected to the PWM hub, then the PWM hub I connected to the 4 pin connector "CPU_OPT". The two fans from the CPU cooler I have joined to a splitter and connected to the 4pin connector "CPU_FAN".
However on the motherboard there are additional fan header connectors, 4pin "CHA_FAN1,2,3,4" & 5pin "Ext_FAN", should I have connected the fans to these connectors instead of the PWN hub. In the BIOS I can see two of the fan detectors active which I assume is the PWM hub and the CPU cooler.
Now I may have bought the wrong fans to get them to work with the PWM hub correctly, as the same model I purchased was already installed in the case I assumed I was doing right, but I have since found that there are PWM specific fans that vary speed dependant on the heat build up. So I assume the fans I have will just operate at a constant speed.
My apologies if my questions are dumb in any way but hopefully someone can point me in the right direction or suggest changes?
Thanks in advance
Intel i7-5820K
Thanks in advance
