My first post here, so a quick hello
Please can anybody offer some assistance with wall mounting an ASIS ROG STRIX XGVQR32 Widescreen Curved LED gaming monitor.
I recently purchased one from Overclockers and also bought a wall mounting bracket that I thought may be suitable.
InLine Wall mount Tilt/Swivel 26-47 inches.
(MO-004-IL)
However upon unpacking the monitor and the mounting bracket, it seems they are not compatable.
The support plate on the mounting bracket does not fit within the confines of the cavity where the original stand was fixed.(once removed)
Longer narrower bolts than supplied with the wall mount, would be needed to make a quick fix solution, but having invested a fair bit in purchasing the monitor, I dont want a botch up job with the wall mounting.
So a few questions if anybody can help.
Is there an alternative wall mount that I should purchase for this particular monitor?
Is there an adapter plater or modification that I can fit to the mounting bracket I purchased to make a suitable fixing?
(Square peg, round hole at present)
Am I missing something obvious ?
Any help would be appreciated.
Thanks in advance.
(MO-004-IL)
Thanks in advance.
