Hey peeps,
Have logged this with Asus but I don't hold out a lot of hope, so in the meantime thought I'd try here.
Had an Asus Xonar D2X for years that worked fine until the semi-obligatory upgrade to Windows 10. D2X has no official drivers and the unofficial ones I tried were awful with broken-up audio so... ok... new sound card time.
Bought a Xonar SE 5.1 card, installed, drivers updated and connected up to my Logitech Z-5400 speaker system. However I cannot get any surround audio out of the optical output. The logitech supports both DTS and Dolby encoding and if I go into the sound control panel, the SPDIF output on the card has the "Configure" button greyed out so there are no settings I can set for it to tell it stereo/5.1/7.1 etc.
Now, if I bring up the properties on that output, select supported formats, and perform the play test on either DTS audio or Dolby Digital, I get sound output. The display on my logitech front-end alsoc onveniently displays details of the encoding it is receiving - and it correctly displays DTS or Dolby accordingly - so I know that, at some level, it is working.
However, this is the ONLY location/mechanism where I can seem to get surround playing out of the card! Any other method - games, suitably-encoded films or test videos they all just play in stereo. The speakers do not receive an encoded stream. A good test I use is here :
https://www2.iis.fraunhofer.de/AAC/multichannel.html
I download them and play them through VLC just to ensure the web browser or standard windows media player are limitations. All of them, without exception, come out as just plain stereo. No discrete surround output.
Initially I suspected that the card was incorrectly advertised and was incapable of 5.1 audio on the optical output, but the test above proves that wrong because clear the card CAN output both DTS and DD on the optical output.
Any ideas? Trying to narrow this down to an Asus problem or a Windows 10 issue!?
