ASUS Z10PE-D8 WS MEMORY PROBLEMS HELP PLEASE
22 Aug 2016
Hi there i post this yesterday,i could not find the new thread option, thanks to point me to the direction.
Hello everyone sorry i am not hijacking your tread, but i have look all around the forum and cannot find where or how to start a new tread, so please can you help.
I have the ASUS Z10-PE D8 WS ,Since April 2016 and cannot get my project setup with 128GB RAM as yet I am using two CPU's they are the Zeon 2620 , i bought a set of 64GB Rams 16x4, they were CT16G4RFD4213- 36FA2 modules, They work ok .I then decide to add another 64GB Rams they are the CT16G4RFD4213-6FB1, When i install they the System will not boot it is showing b7 system initializing i contact Asus support they say that i need to use the same module of RAM, but they will change the Motherboard for me as it maybe a fault on it, i receive the next Motherboard but i am getting the same result, I then contact CRUCIAL Support, they told me that the modules ending with 36FA2 they no longer make them, they are the older modules but they should work with the 36FB1, as they are the same CT16G4RFD4213
36FB1 is the new module i had the 36FA2 exchange for another set of 36FB1, so now i have all 8 sticks of the same CT16G4RFD4213-36FB1 but again when install all 8 sticks it’s the same results
B7 system initializing, Question is this a normal thing to happen and should I have to wait for hours for it to initializing
The Computer did boot up with 7 stick of RAM install both the 36FA2 and the 36FB1 mixed the problem is when a RAM is in DIMMD1 Slot, it don’t move from b7. I change the Bios setting memory frequency to 1600,but the same result,
Latest BIOS is version 3304 x64 build date 06/2/2016 memory on board 7 sticks of RAM shows 114688 Mb,
CPU-Z nothing showing in Slot 4
Please can you help?
Thank you
I had a reply thank you, but I cannot find the XMP profile on the Asus Z10PE D8 WS motherboard,i went into the BIOS and hit the AiTweaker - Ai Overclock Tuner-i then hit enter and all i see is Auto, Manual- OC Tune , there is no XMP option, as i don't wish to crash this board any further, please can you say which option should i use or where is the xmp found on this board/bios
I must say that i have since advance a bit with the memory all 8 sticks are installed, but it is only showing 98304MB RAM on bootup (platform is Windows 10 Pro)
and when i use the software CPUID CPU-Z when i click on memory it show DDR4 Quad 96GB 1197.1MHZ, when i click on SPD it shows slots 1,2,5, 6,7,8 got in Memory but slots 3,4 none showing, i am not getting the g7 system initializing so far.
Thank you
Cheers
Ok, forget XMP for now and just try each stick individually in the same slot and see if it boots and loads windows.
next, try one stick in each of the slots one by one.
This should hopefully help you find either a bad stick or faulty ram slot.
Hello
Good day I did the one stick in each slot and they all boot up to this message ( Recovery Your PC/Device needs to be repaired The Boot Configuration Data for your PC is missing or contains errors )
All of the slots except slot DIMMD1 none of the memory sticks work in it
therefore it must be faulty, this is the second Motherboard I have tried,
the First one was ASUS Z10PE-D8 WS REV 1.03 This one is REV 1.04
and using the BIOS 3304,
This tells me that the Ram sticks are ok but not the Board's slot DIMMD1 must be faulty.
i install in all slots with the exculsion of slot DIMMD1 i get 114688MB memory then the message
Cheers
