Asus z170-a won't post
14 Oct 2011
Hi all,
Building a friends machine and I can't get anything to post.
RAM light stays on so have the different channel and each module separately.
Ram is 2x8GB KINGSTON fury black. Ddr4 pc419200C15 2400MHz.
Any ideas?
Thanks,
Got both power connector inserted in the board? Front panel on/off switch hooked up to the correct pins?
ClearCMOS>
Disconnect all drives.
Try connecting monitor directly to the board and remove GFX card if you are using one.
then one ram stick at a time.
