ASUS-Z170-E Posting issue
26 May 2008
Hey all I'm just looking for some help
I ordered the following bundle which arrived today but I'm having some issues getting it to post.
https://www.overclockers.co.uk/8pac...e-gaming-bundle-bu-050-as.html#p=thqz~;thrz~*
I'm getting a solid DRAM led. It seems to only post with one individual ram stick installed, if I have both or the other one it doesn't post. Has anyone else had this problem?
I've removed the motherboard from the case, as I thought it could be something to do with the stand-offs.
Edit.
Should not I've tried the following with the listed results.
Ram stick 1 in any slot boots to bios fine.
Ram stick 2 in any slot either get a Solid DRAM led or a CPU Led
RAM stick 1+2 in the grey slots, I get a solid DRAM LED.
Have tried inside and outside the case.
Press the MEMOK button? Get in to BIOS that way, then set the timings but really it should be working out the box if its an 8pack bundle.
