Asus Z790 Formula
18 Oct 2002
Bristol, United Kingdom
Hey All,
I recently splashed out and bought a new machine, I'm now at the point where I am going to start building and got most of the way there, I was about to put the CPU in noticed that the socket didn't look quite right, and there's one random pin out of alignment.
I've attached a pic below of what I'm seeing apologies for quality I only had my phone, I'm assuming this is bad enough that I should send the board back as faulty?
Any advice greatly appreciated.
Looks fine to me, your lucky I bought a asus z790 apex the motherboard was bent and the cpu socket was wrecked with a long line of pins that where bent, lucky I stood my ground and got it replaced.
Hey All, from the above 2 posts hopefully I'm being too cautious, but this is the bit I'm concerned about. When you zoom in on the pic you can see it a little clearer.
It does boot up and has seemed to install windows fine.
Have you got both memory channels?
Did you use the IGP or the DGPU? If you used a DGPU, what is the PCI-E speed in CPU-Z?
Yup both memory channels are up and running, although I was getting errors in memtest, 1 or 2 in 4 passes but consistent. Assumed I also lucked out and bought defective memory so that's been sent back to, to swap over.
Using a DGPU (4090) and is running at 16x so looks all good there?
Try fix the bent pins.
Well I seem to have gotten it in a better position and the machine is still booting so fingers crossed.
