Asus Z97-A BOOT_DEVICE_LED
24 Jun 2015
Every now and then my new Z97 A boots till the Asus logo with
"Press F2 or DEL to enter BIOS"
and stops there.
The BOOT_DEVICE_LED is on and nothing else happens.
Then I reboot, nothing.
I unplug 1 SATA cable, an other SATA cable, still nothing (there are 2 in total).
Then after 1 or 2 more reboot, it finally gets to BIOS and then I can reattach everything and it works.
Found similar issues online, but no solution.
The rest of the system is i5-4460, HyperX Fury 8+8 GB, Samsung 850 EVO 250GB and a Hitachi mechanical disk.
Any idea?
I had the same problem with my Maximus Ranger VII.
I seemed to fix it by going in to BIOS, and setting the USB configuration Legacy USB support to disabled also set Intel xHCI to auto instead of smart auto.
I have been booting up for a few weeks now with out any problem.
