Asus Z97-A mouse/BIOS problem...
14 Jul 2005
System
- Asus Z97-A mobo
- Intel Core i5-4670 3.40GHz (Haswell) Socket LGA1150 Processor
- Raijintek Themis Black Heatpipe CPU Cooler
- TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit
- Radeon Sapphire HD 7970 Vapor-X 3GB GDDR5 GPU
- SuperFlower Golden Green HX 650W "80 Plus Gold" PSU
- Microsoft USB Comfort Mouse 4500
- Microsoft PS/2 keyboard
Drives
Samsung EVO SSD
C: - 60Gb Win7
D: - 60Gb Win??
2 x WD 2Tb HDD in RAID1
E: - 650Gb "Data"
F: - 250Gb "Programs"
G: - 1Tb "Games"
Y: - DVD-R
Z: - DVD-R
Fitted this system together last night and I've had the same problem since I
first booted it up. When I'm in the Asus BIOS screen, the mouse pointer flicks
around as if someone is jiggling the mouse about. It makes it just about impossible
to navigate around the menu system as the mouse pointer constantly returns to
the centre of the screen, though I just managed to do enough in the BIOS using
the keyboard to set up my hard drives the way I wanted them.
Before someone says "try another mouse" I did, but the mouse cursor even
moves when there's no mouse connected at all! Not as much as when a mouse is
connected but it STILL jiggles around a bit, returning the mouses focus to the
centre of the screen.
I tried updating the BIOS via the Utlility in Windows - twice - and I'm now on the latest
available BIOS for the board, but both updates made no difference to this problem.
There's been no problems at all in Windows 7 (64-bit) with the mouse or anything
else - everything is running fine, and the CPU is sitting around 29-31°C with the big
120mm Raijintek fan only spinning at around 550rpm.
It's really annoying me that I cant get into the BIOS to have a look around.
Anyone any ideas on what might be causing this?
:confused:
you don't have any gaming controllers connected do you? only thing ive had similar is in windows when my controller is connected it will move the mouse cursor around
can only be a bios bug/incompatibility imo it shouldn't be doing that,tried all the usb ports?
you should be ble to do everything with just the kb anyway,not ideal but will do till they hopefully fix it
That was it!!! Disconnected them (two Saitek USB controllers)
rebooted and et voila, a functioning mouse in the BIOS!
Nice one, wazza - spot the noob here who's rebuilding his entire system
for the first time in nearly 10 years.
Have a cyber-pint on me.
