Asus Z97-K, won't boot with graphics in, help!
18 Oct 2002
Sussex
New build, the Asus Z97-K boots fine and displays through the onboard hdmi output to my monitor.
MSI HD 7770 GHz Edition 1024MB GDDR5 PCI-Express Graphics Card
When I slot this in (not forgetting to plug in its own power source) the machine does not boot, the keyboard/mouse don't light or become active, the display comes on and then shuts down due to "no source" The cpu spins up, no beeps.
Tried the card in both slots.
Any ideas?
First thoughts are bios or underpowered psu (which is a Antec VP450P 450W '80 Plus' Continuous Power Supply) but my research shows that a 450 should fine.
I would point to the graphics card initially. Can you maybe try the card in another PC to confirm it works and has no issues. Then we can then narrow down to the card itself or something on your setup.
I had a very similar experience once, after lots of head ache ended up being the cards were fine my pcie motherboard interface was faulty. :(
Hope that's not the case for you though.
try cmos reset? By coincidence i have the same board and i had the same problem (ie no display but everything else coming on)
Could be the PSU. Not confirmed as haswell compatible here,
Antec
According to Antec, the following units are "fully compatible" with Haswell:
•EarthWatts Green: EA-650 Green
•EarthWatts Platinum: EA-450, EA-550, EA-650
•High Current Game: HCG-750, HCG-900
•High Current Gamer M: HCG-520M, HCG-620M, HCG-750M, HCG-850M
•High Current Pro: HCP-750, HCP-850, HCP-1200
•High Current Pro Platinum: HCP-1000 Platinum, HCP-850 Platinum (OC link), HCP-1000 Platinum (OC link), HCP-1300 Platinum (OC link)
•NeoEco C: Neo Eco 620C
•Signature: SG-650, SG-850
•TruePower Gold: TP-550G, TP-650G
•TruePower New: TP-550, TP-650, TP-750, TP750 Blue
•TruePower Quattro: TPQ-850, TPQ-1000, TPQ-1200, TPQ-1200 OC
•VP: VP550P V2, VP650P V2, VP650PM
•VP F: VP550 F, VP630 F
However, the compatibility of these units "has not been confirmed yet":
•BP: BP-350, BP430, BP500U, BP550 Plus rev 1
•EarthWatts Green: EA-350 Green, EA-430 Green, EA-500 Green, EA-750 Green
•High Current Game: HCG-400, HCG-520, HCG-620
•High Current Gamer M: HCG-400M
•NeoEco C: Neo Eco 400C, Neo Eco 450C, Neo Eco 520C
•VP: VP350P, VP450, VP450P, VP550P
•VP F: VP450 F
