Hey Guys,
So yesterday I replaced my ageing DFI LanParty Motherboard and P4 Prescott 3.2ghx Gear with a Nice Asus P5N32-E-SLi 680 and an Intel E6600 Dual Core CPU.
Current system Spec.
Intel Core2 Duo E6600
Asus P5N32-E-SLI 680
OcUK NVidia Geforce 8800 GTX 768 (Fitted With a Thermalright HR-03)
SoundBlaster Audigy
1 GB Balistix DDr2 5300 Ram (2 x 512mb)
1 GB Kingston DDr2 Value Ram (2 x 512mb)
650watt Dual SLi PSU (3 Days Old)
Thermaltake 'Shark' Tower with 120mm front and 120mm rear.
22" Dell E228WFP Monitor
Logitech G15 v.2 Keyboard
Microsoft Sidewinder Mouse
Windows Vista 32bit
All running current drivers as of yesterday. Vista is upto date including SP1.
Had nothing but problems since building it, I am thinking its down to ram but will explain a little.
In Windows, Adobe Photoshop CS3 etc its Fine. As soon as I start gaming then thats when the problems start.
Can play COD4 Single Player for about 10-15 minutes then it locks solid with nothing but a Sound loop. Resetting the pc is the only way to get going again. CSS/Portal etc work fine. Runnin TF2 I am getting approx 2-5 fps if it does'nt crash within 2 minutes.
Currently running the mb with Setup Defaults loaded to boot.
I am sure its the ram as its getting pretty hot etc. Have tried to change settings in the bios for the ram but end up only getting as far as the first Ai boot screen with 'Hit delete to enter setup' if I set the ram to 3-3-3-12 as found on the net for this ram. I have tried removing each make of ram, i.e. Only running the Crucial Ballistix and so on but still no different.
What are the best settings for my current setup as far as ram is concerned. Should I ditch the ram and get some newer ram that would be better suited to my board (Please advise what would be a good but not too expensive ram)
Also with my CPU, what can that be run at. Its got a massive Zalman HeatSink/Fan combo on the rarely seems to go above 35 degree's.
Thanks in Advance Guys, would really like to get this sorted asap.
Regard
Chris
SoundBlaster Audigy
Windows Vista 32bit
Regard
Chris
