Hi guys if any of you have seen my project log you will know im having a problem fitting a fan to the bottom of the case. Ive tried fitting the fan with the fan screws that came with the fan but they go straight through the holes and CM havent included any with the case to fit a fan there. Ive even tried contacting CM and had zero responce from them which is rather disappointing for such a big company. Has anyone any suggestions please really want to get my fan fitted to the bottom of my case.
Thanks
Thanks
