Athlon 64 4000+ temps?
26 Sep 2005
Just got mine from OcUK (KAB1E). Temps look to be sitting pretty high at around 53 C under load with prime 95 and with a gigabyte g-power pro cooler fitted.
What temps are other people seeing?
And it's not even that hot tonight!
cheers.
IMO, it is quite alright. Mine hits 52 C in Obvilion. You might want to check the way you install your cooler and the thermal dynamic of the case. You can also compare it to your old ref. HSF. which might be higher underload.
my 3200 (venice) which i took out didn't go this high.
At 55 now!
Will think about putting the full 12 V back through the rear fan to get some more air flow.
Anyone else got temps for these chips?
Took fan of heatsink and cleaned the heatsink of dust.
Re-applied thermal paste (a bit less this time).
Returned the rear fan to 12V (was 7V modded for less noise).
Temps down to 48C under load now.
There's nothing like changing 3 things at once so you don't know what fixed it...
