Athlon 64 4000
12 Oct 2005
Cheam
Currently I have an Athlon 64 3200 Venice. Would I see a performance difference if I upgraded this cpu to an Athlon 64 4000 San Diego? Does the athlon 64 4000 overclock well?
The Amd 4000 OEM Cpu are hitting 3ghz at a very low price theres not many left as there all FX 57 beaters
maybe sell the cpu you have now and buy the above
you shouldn't have too many problems clocking an extra 600mhz if you're at 2.4 as your sig says
not to be sneezed at, but is it a gaming rig or multimedia etc?? you might be better off going dual core now there prices have dropped also.
