Athlon Headache please help me :D !!!
20 Jul 2014
Ok i hope ill get help here i have this CPU- http://prntscr.com/5zuir4 this is my motherboard- http://prntscr.com/5zuj5s and this is ram im using - http://prntscr.com/5zujow http://prntscr.com/5zujvw http://prntscr.com/5zuk2m !! Problem is it refuses any type of manual Overclock i tied tons of stuff i got sugested on Linus tech tips forums and all ended up as fail !! heres a list of stuff i have done !! : i tried to follow all steps linus did in this video http://prntscr.com/5zultl , updated bios to latest version http://prntscr.com/5zumkf .. this are stuff that hap[pends to me any time i try to manualy oc: http://prntscr.com/5zun3t .. and these are some bios info : http://prntscr.com/5zunxh , http://prntscr.com/5zuodl i accidently put multiplier on 260 stock is i think on 215 .. and this is only way i can overclock my cpu but still its too slow only 2.46 ghz after 7% oc http://prntscr.com/5zup7v , i tried to hit manualy 2.46 ghz and ended up with fails .. is there anything i can do to oc my cpu i need that extra speed for some time im saving up fior i5 but till i get enough ill lose all my nerves with this athlon.. Please help me
I've just read what I'm assuming is your thread on the linustechtips.com forum - amazed you haven't given up entirely since April last year! :p
First off - turn off 'Cool and Quiet' in the BIOS since that doesn't tend to get along well with bus speed overclocks. Next, turn down the multiplier one notch for your RAM and for the HT Link (might be called HyperTransport something-or-other) - if it's 5, turn down to 4, if 4 then 3. If it's listed by bus speed, same applies - just go down one setting in speed. Then try overclocking the CPU bus frequency. That rules out the memory controller and RAM being your limiting factor in the overclock.
Oh, and probably set your PCI-E frequency manually to 101. I always found that more stable when I was overclocking AM2 and AM3 setups. Don't know why, but it worked for me so I never really questioned it. Thinking back it was probably a hang-up from the old Athlon XP days where certain chipsets wouldn't lock the AGP and PCI bus speeds unless you manually set a speed one tick higher than stock.
same problem i oc it save stuff it works i restar pc again to go further it wont startup i restart again and it reset oc i oc again and it works i turn off pc after i finnish i turn it on oc error every single time same story !!!!
Tried turning up the vcore (CPU voltage)? Don't go too mad with it, standard voltage is 1.4V so maybe go up to 1.45-1.5V and see if that lets it work. What CPU cooler are you using?
stock one .. works like charm keeps temp around 39-40 ( its usualy 35-37 when its clean of dust xD but its cold outside so its a bit dusty inside case ) celsius @ 2.46 ghz
http://prntscr.com/5zw6gz oki its working atm after 2 straight restarts with this slight voltage increase few more ads and it starts showing yellow numbers wich i suspect mean danger zone so i was sfraid to go further with voltage stuff now ill turn it off and on to see results if it survives and starts up it will be best day in my life if not im back to square one
Beyond even my beliefs its working ( for now it allready happend to me that oc worked for 1 full day before going back to old behavior of failed overclock) guess ill wait and see what will happend in next 24 hours
Well, keep a watch. Also keep a watch on temperature.
By the way, HT link speed is clocked up a bit. In the BIOS, is there an option called CPU/NB frequency? If there is, knock it down one notch if you go any higher on the CPU bus speed.
On that last screenshot, you've still got the HT Link speed waaaaaaaaay higher than stock. That won't help any overclock stability.
