Hi everyone,
I have failed over and over trying to unlock the 4th core and gave up but decided to overclock the CPU running 3 cores.
I am fairly new to this and have been reading around on how to do it. From what I gather my only way is to increase FSB as my multiplier is capped at x15. I have done this in a small step to get 3300mhz but what I am not too sure about is reducing the DRAM Frequency. Lowest I can put mine is 850mhz in the BIOS, do I keep it low as that or put it higher? I am using 1333mhz dual.
Also the voltage seems a little odd. I have it set to Auto and it is at 1.425, and since I have overclocked and running prime95 test is sitting at 1.5v. Is that totally over the top as I cant find a site that tells me my stock voltage.
I cannot find Vcpu-nb voltage on my BIOS only Cpu over voltage my temps at the moment are 38-39C but would that be because the voltage is set so high?
Oh and im using Titan Fenrir for cooling.
Thanks for any replies
