Hi everyone,
I recently built a new pc over the weekend and all is running fine but I was interested in trying to overclock or possibly unlock a core if I was lucky enough.
I looked around on the internet on how to do it and tried but I didnt feel comfortable trying to fix my problems I had incase I made a mistake as this is my first time.
I am using a MA477T Asus motherboard, 4GB RAM 1333Mhz, ATI 5770. I turned AAC on, left it on auto, then enabled Unleashing which then gave me the core unlock options either manual or auto up to 6 cores. The problem I have is the computer restarts after exiting the BIOS then doesnt power up fully. The power light comes on as does the all fans but nothing else. I then have to turn it off from the PSU until the light goes out on the motherboard then switch it back on to get into the BIOS. Is this just saying the 4th core is bad and not to bother or am I missing something?
I looked into it being the voltage but I was unsure about what I was adding, whether the voltage over CPU was the actual setting or adding that voltage to the stock voltage...
I dont mind if I cant unlock a 4th I did after all buy a 3 but I just want to know for sure lol. I may be interested in overclocking it slightly anyway.
Does anyone know if this processor will bottleneck with the 5770 running games or will it be ok as it is, as thats the main reason for me trying.
Thanks for any help.
