Hi all,
I have just got hold of an AMD Athlon XP 3200+ CPU to replace the 2600+ currently running on my MSI K7N2 Delta.
When I try to set the FSB to 200 in the BIOS and then reboot, the system just hangs with a black screen (no signal) on the monitor. If I leave the FSB at 100 or 166 the system boots fine. The BIOS and CPU-Z report the processor as running at 1.1GHz when I am sure it should be at 2.2GHz.
Whats going on? Have I been ebayed a duff processor? Or is there some sort of jumper/BIOS setting that I am missing.
Thanks in advance
Thanks in advance
