I recently got my old PC that I used at work away home with me. For as long as I remember, it was an AMD XP2000. I bought a barton XP2500 to swap in.
When I removed the heatsink though, I was surprised by the label on the processor. Turns out all this time it was an XP2600 running at a lower FSB. Sure enough, I went into the BIOS and bumped it up from 133 to 166 and it runs just fine. GRR! Just think of all that compile time I could have saved at work had I known!
Now, the XP2600 is a thoroughbred. How does this perform against the slower but higher cached barton XP2500?
At stock they will be very close with the 2600 just edging it. But the Barton might have more headroom if you can overclock.
nostalgia...
IIRC you could run up to 2v cpu vcore if you select the 'above 1.85v option'
