- 2 Oct 2008
just wondering about what speed DDR3 would be best to use for
with a 240E Athlon II
AMD website says the supported ram from the on-board controller is this...
Type of Memory Supported
X2 - Support for unregistered DIMMs up to PC2-8500 (DDR2-1066MHz) -AND- PC3-8500 (DDR3-1066MHz)
X3 and X4 - Support for unregistered DIMMs up to PC2-8500 (DDR2-1066MHz) -AND- PC3 10600 (DDR3-1333MHz)
does that mean I would have to clock the ram down if I got a higher speed
kit ?
kit ?
