easyrider said:The athlons have a shorter pipeline and can process more data per cycle than a pentium 4.
its like having a pile of coal ,the athlon is the bigger shovel so can move the pile in less shovels
the P4 is the smaller shovel so to move the same ammount of coal it has to move more shovels at a faster pace to move the same ammount.
hope this makes sense its early![]()
hogfather said:OI! That's my analogy
The PR (eg 3500) ratings apparently don't correspond to Pentium 4s (officially they are the speed in mhz that an original Thunderbird 1ghz athlon would have to run at to be as quick, IE a 3.5ghz thunderbird = an athlon 64 3500) - in reality it basically is supposed to be a 3.5ghz p4, but its not as quick as that.
i read it somewhere and it seemed to make sense
radio91 said:Why are the A64's better for gaming?
radio91 said:I always thought gaming was heavly dependant on number crunching and Floating point calculations which i thought the pentiums are better at.
radio91 said:Also whats the difference between different athlons apart from clock speeds, because i see that a 3500+ is clocked at 2.2ghz but so is a 3700+ and the 3800+ and 4000+ are both clocked at 2.4ghz, So whats making the 4000+ faster than the 3800+?
Dace said:The cores have essentially progressed since the first 939 CPU's were brought out as:
Newcastle
Winchester
Venice
San Diego
(I've got a nasty feeling I've missed one out).
radio91 said:How far do you think socket 939 will go? I mean will there be any knew faster cpus released on socket 939 and if so what do you think the maxium speed will be?
