ATI 1900XT New Hardware Found Problem
Sel
Sel
20 Sep 2003
Stoke
I've installed my card and used just the drivers, I've also installed the ATI Tool Tray and my card works perfectly but I keep getting hardware drivers not installed error in windows.
The only fix I can find for this is to install the Drivers that came on the CD then install the newer drivers but I hate to install new drivers without removing the old ones first, if I do that I get new hardware found please install the drivers.
Thet are installed for crying out loud why won't XP listen to me.
Your system is just looking for the WDM drivers,you can get them from the ATI site,in the catalyst download section.Install these and your problem will be solved. :)
Did u install the vivo/wdm drivers aswell as the regular card driver ? I was having similar problems until I installed vivo/wdm drivers.
