Edit: To cut a long question short - these are all the same effectively, right? The middle ones are ground, so it shouldn't matter if they're swapped over?
I bought a power connecter from a local store which was different to my brothers, but modified it to match my brothers. I'm having problems with the computer and want to rule this out as a problem!
[mirror][mirror ]
[mirror][mirror ]
