Hi,
I recently bought a hidef tv, and have been trying to hook up my media pc to it. It's using an ATI 2600xt gfx card.
Was initially using a dvi to hdmi cable, and found the display didn't fill the screen. Found the overscan options in the CCC, and when I set this to 0, it showed a perfect 1920x1080 1:1 picture, which completely filled the screen and looked great.
The problems started when I tried using the hdmi adapter on the card. I could not get any audio through at all, even though drivers were present etc.
Then realised that the adapter I was using was not the one supplied with the card. Found the correct adapter (which was black, while the other was grey) and used that instead. Now I get audio of hdmi (finally!!) but the display is off. I'm still using 1920x1080, but no matter what setting on the overscan scale I use, its never a perfect 1:1 mapping anymore and looks blurry/fuzzy.
Any ideas why using the audio enabled dongle would effect the display like that? I've tried updating to the latest drivers but its still the same.
At the moment it looks like I can either have a perfect picture but have to use an audio card & seperate lead, or use the hdmi audio and get a fuzzy picture.
