Hi.
I am having some issues with this graphics card. Its an XFX 5770 (blower type cooler). I swapped it for my Nvidia GTS240 with my cousin because he had some horrible issues with motherboard compatibility.
Well my issues are less severe. I am getting a bit of artifacting in some games like L4D2 and BC2. I am running 10.9a drivers and I have disabled over drive in CCC.
In L4D2 when an item or someone is glowing white checker appears within the middle of glowing outline.
For BC2 in the main menu I get little black dots over the buttons that kind of judder.
I have not tested any other games but I guess similar things will happen as well.
Well originally the bios was an unlocked Asus bios I tryed upping the volts a little bit with MSI afterburner to see if it removes the artifacts but nope. I just flashed it with the latest version of XFX balck edition bios which has higher clocks and volts but the issues are still there.
My cousin has sent this card to OCUK for an RMA because of the issues and they tested it and they said it runs fine with 7 different games but I am also getting some of the isues. I think its the card even though OCUK said it was fine.
Should I send it off for an RMA then? Obviously flashing the bios back to the standard XFX bios.
