Hey Guys,
Had my new PC a while now and I bloody love it. Dont have any graphics crashes or anything anymore and it works great.
I do however have one small issue, and that is the sound through the HDMI.
I currently have the sound from my computer going through HDMI into my Toshiba telly, and then from that into a set of speakers using a headphone cable (not a very sophisticated set up I know, but it works great).
To the problem... Basically, if the sound is not in use from the graphics card, the sound seems to turn off because when I then play a sound, it cuts off the first 1 - 2 seconds or so, and then plays fine after that. I first noticed it when playing some 4 second wav files. I had to put media player on repeat to hear the whole thing. It also cuts off the start of songs on iTunes and Spotify.
I have had a look on the net to no avail, and before contacting ATi, I thought i'd see you guys first.
I don't hear the windows log on/log off sounds as they are too short. It does it even when there has been no audio for about 5 seconds.
Hopefully you guys can help, it is quite annoying.
Cheers.
Cripple.
PS Hope you all have a great christmas
Cheers.
Cripple.
