ati 5850 problems
6 Jun 2010
nottingham
ive just installed my new kingston 128gb v100 ssd and now my computer is not recognising my 5850 graphics card ????
any ideas...
in desperate messures :S :(
everything apart from grf works fine, i moved my gfx card into a diff slot, booted windows, it picked it up but i cannot do anything with it, i replaced my 2raptors in raid 0 for ssd if that helps
would i need to change anything in the bios ?.
i know a small amount of pc stuff but surely it should be picking it up straight away right ?
Sometimes the BIOS keeps the old settings,you got nothing to loose doing a BIOS reset it won't do any harm,also make sure you running the ssd in achi mode you can change that in the BIOS as well,good luck hope you get it up and running
