ATI 6850HD Upgrade
28 Jun 2006
Hello all, i'm looking for a cheap graphics card upgrade. Second hand from the MM would be fine. Budget is as cheap as possible but something that will help.
Thank you :)
Tomshardware produces a table that shows roughly where each GPU fits in comparison to each other:
http://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
Generally, a move of three tiers upwards is a very noticeable improvement in graphics power, only moving one tier up will require an FPS counter to notice the improvement.
Depending on your budget, I'd be looking to try to find a cheap 7870, R9 280, 7950 or 7970 on the AMD side (in that order or preference), or a 660Ti, 670 or 770 depending on what comes up for the right price. If you can stretch to an Nvidia 970 or an AMD 290 or 290X, you will be looking at easily triple your current GPU power and should give you a very big grin as a result! :D
solid info Stu - :) yep without knowing budget hard to recommend - if you want new and best jump most likely would be 470 4g for 1080p.......but again hard to recommend without some sort of budget :D
As an ex owner of a 6850, I can tell you if you can get a 7950 for around £50 you'll be laughing, massively faster, and they're going in that ball park second hand now at times :) (assuming your PSU is up to the job).
If you can find a R9 290/280/285 or a 7970 you're also doing well.
Nvidia side you'd be looking at something like a 970 (960 not worth it IMO as they had too much premium on the RRP) :)
I'd keep with AMD if looking for a cheap card to last you as long as possible.
How much do secondhand 380x's go for?
I'd look for a 390, 390x, 290x (non reference only) or a 380x, If neither of those are in budget I'd look at getting a 290, 285 or 380.
