ATI 7970 4 monitors?
As far as i am aware, most cards can only display two via DVi/HDMI, and you have used both on both HDMI.
Which 7970 do you have?
If your monitor has a DP input and your card has a DP or mini-DP output, you don't need an active adaptor.
To connect a DP output to a DVI or HDMI input, you need an active adaptor, which is typically £15-25.
