ive running an AGP ATI 9550 at the mo (untill me new pc rebuild)
ive just bought a Hanns.G 19" widescreen from OC with the VGA and DVI imputs.
i was hoping to run the monitor dvi, leaving the vga for my xbox.
heres my problem if i boot normaly vga, then plug in the dvi, tell the gfx card in the latest ati catalys software to switch to dvi it does.
UNTILL i reboot, if ive just got the dvi in it posts, runs through the windows loading screen, then no display. but if i unplug the dvi and plug it back in again it come on. or if i had the vga cable in it would come on that way
how to i force my card to boot in dvi
any help would be grand
Marshall
Marshall
