ATI and GeForce
A 5870 with a non-reference heatsink is probably your best bet if you want a high-end cool/quiet running card.
I've not tried the new NVidia cards but I found the 6970 to be extremely hot until I put it under water.
One of the ATI 5000 series strengths was it was cooler running.
As above, probably best bet for power and cool running is a 5870.
I have a 5870 and its a good card, and it runs cool too, which is why I choose it in the first place.
If you are not a fan of graphic card giving off too much heat but want to get a card of this gen that's still reasonly quick, then a GTX560Ti or 6950 1GB/2GB with a custom cooler is the way to go. They are both slightly faster than 5870 out of the box, but are much more overclockerable.
I want cooler, faster and less noise.
As you know, the Raedon is pretty hot as well as noisy.
I don;t mind to spend a bit more on an nVidia if it is quieter and cooler.
If I run DCS Shark or DCS A-10, nVidia is faster or ATi is faster?
Supposedly with DCS the graphics card isn't usually the bottleneck (especially if you have a HD 4870) - the CPU is. Have you tried overclocking your Q6600? Your motherboard is great for overclocking and you seem to already have a half-decent aftermarket CPU cooler.
If you want to get a new GPU then I would go for the HD 6950 2GB, that game seems to make use of lots of VRAM - especially if you turn the settings up.
Buying an SSD is also an upgrade worth considering.
Is you i7 920 good enough for this game?
I haven't played the game myself (though read quite a few things about it and may well pick it up in the future), but looking at posts by people who play DCS: A-10C Warthog, a CPU like an i7 920 (or one of the more modern sandy bridge CPUs) handles this game very well- mainly due to very good performance in lightly threaded apps.
My Powecolor 6970 aint to bad never seems to go abouve about 70/75*c when gameing noise isant to bad either.
I would say louder than my old 5870 was before the fan started to die, but still quite abit quiter than my old GTX280.
Forget all the Nvidia vs ATI stuff. Decide on a budget then buy the best card at that price. Doesn't matter if it's red or green.
What he said, there are only a few programs that prefer red or green, i play fsx and that prefers nvidia by quite a bit so i am team green but equally if i did not play fsx i would be happy with a red card
I'm quite impressed with my 570. 35 - 40c at idle, 70 - 75 c at load. Thats coming from a 470 which sat at 40 - 45 c idle and 85 - 90c load.
(Both 470 & 570 overclocked also)
All the new 5XX series cards from nvidia are great for their lower temps.
Whats the noise like on the 570's? I hear the vapour chamber design is quite good.
