- 11 Sep 2008
- Northern Ireland
when i go download 8.11, i remove 8.10, restart and install. But when I go into CCC, and go to software information, it still says my version is 8.10. Any ideas?
Did you do a full un-install of the drivers, and then a driver sweep/clean in safe-mode before installing the .11's.
Driver Packaging Version 8.541-080923a-069996C-ATIwhat Driver Packaging Version does it show, as that will be the most important, 8.11's should be 8.552-, so if you have that, then you are running the 8.11 drivers.
