ATI card better color than Nvidia?
2 Feb 2006
Chepstow, Wales
Just a thought.... when I first had a PC(very long time ago)the only graphics card I ever used was an ATI.
Monitor was an old Elonix(xcuse spellin)but the color was good with the ATI card.
More saturated is the only way I can describe it......
Then I started using Nvidia cards and to me the colors were not as strong or saturated as when using ATI.
For a while I ended up having to use an ATI card until I could get a new Nvidia based one and again the color seemed a lot better.
Does that make any sense or is it a trick of the mind?
The card I use(plenty good enough for my needs) is now a 9600GT 512Mb Zotac.
What ATI card is more or less the equivilent of the 9600GT?(Xcuse any bad spellin as too early in the day).........:confused:
There is a setting in Nvidia CC called Digital Vibrance. Set this higher and you`ll see a vast improvement.
You've got to remember that the cards come out from two completely different manufacturers and that they set the defaults differently for the colour.
