Ok buying a second hand card just can't decide between an x1900xtx which I would buy a cooler for it (Ive heard the standard cooler is noisy and pretty pants) or a x1900xt which has that iceq3 cooler fitted. My question is, is that cooler much better than the standard x1900 coolers in terms of noise and actual cooling? If so would a x1900xt with this standard cooler be worth the cheaper price (£15 or so, the actual cards are the same price) that I would save from buying cooling for the x1900xtx (Im guessing with a decent heatsink it can probably be safely overclocked aswell)?
Cheers in advance
Cheers in advance
