ATI Catalyst 6.6 out
ray
ray
18 Oct 2002
XP drivers here:
https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=640
New Features
This release of Catalyst® introduces the following new features:
* Avivo™ Video Converter Extension for Windows Media Center Edition
* Theater 650 Pro TV Tuner Support
Catalyst® 6.6 introduces a Windows Media Center Edition Video Conversion utility. This utility will allow users to convert video content that is either recorded or available to Media Center Edition to a variety of different formats. The video content can be converted to MPEG-2, MPEG-4 SP, MPEG-4/AVC and Windows Media. iPod video and Sony PSP’s are also supported with an optimized profile for these devices.
Catalyst® 6.6 includes support for NTSC/ATSC and PAL/SECAM/DVB-T products based on the Theater 650 Pro TV Tuner chip. The Theater 650 Pro is a new chip from ATI for multimedia cards and DTV-on-a-chip solutions, integrating hardware video encoding, digital audio with noise reduction, and hardware PVR functions in a single chip.
Performance Improvements
As with most Catalyst® releases, performance has increased in various situations.
* Far Cry performance improves 4-5%. Larger gains of up to 18.3% can be seen when using anisotropic filtering.
* Fear performance improves as much as 8.5% on X1800 and X1900 Single card systems and as much as 14% on X1800 and X1900 Crossfire systems.
* Splinter Cell (original) performance improves as much a 7% on X1300 and X1600 Crossfire systems.
Issues Resolved in Catalyst® Software Suite 6.6
The following section provides a summary of the issues that are resolved in the latest release of Catalyst®. These include:
* Catalyst® Control Center: Connecting a display device capable of displaying a resolution of 1680x1050 to an ATI Radeon® X1900 no longer results in the display mode of 1680x1050 not being available in the Display Manager aspect. Further details on this resolved issue can be found in topic number 737-22011
* Using Catalyst® 6.3 or higher along with the MMC version 9.13 and performing a TV channel scan no longer results in some higher TV channels failing to be detected. Further information on this resolved issue can be found in topic number 737-22381
* Catalyst Control Center: Playing a media file using the Windows Media Player version 10 no longer results in Theater Mode exhibiting the same behavior as the Same on All option when clone mode is enabled 737-22504
* The pulldown detection check box is no longer greyed out under the All Settings for bob and adaptive settings found in the Catalyst Control Center 737-22508
* Clicking the Default button for AA and AF now restores the default setting for AA and AF 737-22512
* Placing the mouse pointer over the Temporal anti-aliasing check box found in the Anti-Aliasing aspect of the Catalyst Control Center no longer results in the tool tip for Let the application decide being displayed 737-22517
* Theater Mode is now functioning properly under the Windows 2000 operating system when clone mode is enabled 737-22614
* Audio is no longer lost when quickly and repeatedly toggling between two TV channels 737-22615
* The Desktop Area list found in the Display Settings is now translated for the Russian language when using the Basic View of the Catalyst Control Center 737-22519
* Setting the Catalyst Control Center skin to Quick Silver along with the display resolution to 800x600 when the language is set to Greek no longer results in cropped text being noticed in the Video->All Settings aspect 737-22529
* The Apply button in the CV Properties aspect of the Catalyst Control Center now become active when adding a custom format 737-22538
* x29: AV no longer occurs when fast window tracking is set to on 737-22643
* Minimizing the TV window using the TV Adjustments found in the Catalyst Control Center followed by attempting to drag the TV window around the desktop using the mouse no longer results in the TV window failing to move properly 737-22539
* DVD playback no longer blinks and the system entering a busy state no longer occurs when using the Windows Media Player v10 and having Theater Mode enabled in the Catalyst Control Center 737-22616
* Connecting a CRT as a secondary display device and enabling clone mode no longer results in unsupported display modes being available in the Catalyst Control Center for the CRT 737-22617
* HDTV custom format is now maintained when clone mode is enabled 737-22618
* Enabling Clone mode followed by opening a full-screen DOS prompt no longer results in the DOS command screen failing to exit properly on the secondary display device 737-22619
* Swapping between the primary (LCD) and secondary (CRT) display devices on a system containing an ATI Xpress 200 series no longer results in the LCD display device failing to display and image when attempting to resume from hibernation mode 737-22622
* The mouse pointer no longer intermittently fails to be displayed on the lower portion of the secondary display device when the option to Stretch main horizontally found in the Catalyst Control Center is enabled 737-22623
* Connecting both a CRT and a TV and keeping the TVout disabled, along with setting the desktop resolution to 1280x1024x32bpp no longer result in the default color setting found in the Catalyst Control Center failing to be restored when changing the gamma setting 737-22644
* GLView v 223: Setting the display resolution to 2048x1536 32bpp at 70Hz no longer results in an error message being displayed when attempting to run the Rendering tests 737-22625
* Setting AA to 8x or higher no longer results in corruption being noticed in the Anti-Aliasing preview of the Catalyst Control Center 737-22626
* City of Heroes: Display corruption is no longer noticed when playing the game under Windows XP with an ATI Radeon X1x00 series product 737-22627
* Enabling extended desktop mode and playing back HD content no longer results in corruption being noticed in the playback window 737-22628
* An error message is no longer displayed when trying to edit a Hotkey function in the Hotkey Manger under various supported European languages 737-22629
* Quake4: Texture corruption is no longer noticed when playing the game 737-22385
* Age of Empires III: All the buildings and silver mines no longer shimmer at the same time when right-clicking on an object 737-22630
Known Issues for Catalyst® Software Suite 6.6
The following section provides a summary of open issues in the latest version of Catalyst®. These include:
* Anarchy-Online: Screen corruption may be noticed when walking or running through the terrain. Further details can be found in topic number 737-22016
* Cold War: Playing the game with the display resolution set to 1600x1200 along with AA set to 8x and CrossFire™ enabled may result in a ghosting effect being noticed. Further details can be found in topic number 737-21661
* Lord of the Rings: The Battle for Middle Earth: Playing the game under Windows XP SP2 using an ATI Radeon® X800 series product may result in intermittent display corruption being noticed. Further details can be found in topic number 737-21458
* Neverwinter Nights: Playing the game under Windows XP on a system containing an ATI Radeon® X800 series, may result in the game exiting to the Windows desktop and an error message being displayed. Further details can be found in topic number 737-21466
* Path of Neo: Texture corruption may be noticed when playing the Kung Fu level. Further details can be found in topic number 737-21464
* World of Warcraft: Enabling CrossFire may intermittently result in the character appearing off center Further details can be found in topic number 737-22017
* The Apply button in the Custom settings of the Advanced mode, found within the Catalyst® Control Center Video standard settings, is grayed out when playing a media file. Further details can be found in topic number 737-497
* Connecting an HDTV to an ATI Radeon® X700 series may result in the HDTV being detected as a CRT or TV under the Windows XP operating system. Further details can be found in topic number 737-20783
* The PAL FM fine tuning algorithm is currently using 200 MHz bandwidth which may overlap FM channels resulting in the same FM channel being found several times during the scan function. Further details can be found in topic number 737-20979
* Launching the Adobe Gamma calibration application and moving the gamma slider back and forth, may result in the Task Manager being filled with cli.exe until the system becomes low on memory. Further details can be found in topic number 737-20980
* Connecting two display devices to an ATI Radeon® X1600 series product may result in the device manager failing to detect the secondary display device. Further details can be found in topic number 737-21266
* Display corruption may be noticed when configuring the DTV channel to 1080i broadcast when using an ATI HDTV Wonder. Further details can be found in topic number 737-21455
* The LG P42SX DVI-D display device fails to display an image when connected to an ATI Radeon® 9000, ATI Radeon® 9200, or an ATI Radeon® 9250. Further details can be found in topic number 737-21456
* OpenGL Extension Viewer: 2.0: Running the Rendering tests may result in a black box appearing when the fog option is enabled. Further details can be found in topic number 737-21457
* Connecting an HDTV as the secondary display device and enabling Theater mode may result in HDTV failing to display an image when attempting to playback a movie with extended desktop mode enabled. Further details can be found in topic number 737-21460
* The IBM T84H display device may fail to display an image when connected to the DVI connector on the ATI Radeon® X800 or X850 series. Further details can be found in topic number 737-21462
* Attempting to re-enable any display device other than the primary or secondary display device that has been disabled by CrossFire™, may result in the operating system failing to respond. Further details can be found in topic number 737-21663
* Installing the a newer version of the Catalyst® Control Center over top of a previous installation of the Catalyst® Control Center may result in the installation of the Catalyst® Control Center taking a long time to complete. Further details can be found in topic number 737-22008
* Using the ATI Multimedia Center to watch TV may result in the operating system restarting when using an ATI Radeon® X1800 series product. Further details can be found in topic number 737-22013
* The Record function currently fails to work when using an ATI All-In-Wonder X1300 with time-shifting enabled. Further details can be found in topic number 737-22014
* Using the ATI Multimedia Center to watch TV may result in the operating system restarting when using an ATI Radeon® X1800 series product. Further information on this issue can be found in topic number 737-22013
* Changing the regional option found in the control panel to Japan followed by installing the display driver no longer results in the TV format failing to change in accordance with the regional option 737-22631
* World of Warcraft: Playing the game for an extended period of time may result in the game failing to respond when using a Radeon X800 737-22632
* Catalyst Control Center: Entering the Overdrive aspect and changing the GPU setting to 509 and the memory setting to 505 no longer results in color corruption and the Windows XP operating system rebooting 737-22633
* Selecting the Plus Da Vinci screen saver and attempting to preview it may result in the screen saver not displaying properly after an extended preview 737-22634
* Battlefield 2: The game may exit to the Windows desktop after the game logo is displayed 737-22635
NO **** SHERLOCK :p
Sorry couldn't resist. Nice find dude.
LoadsaMoney said:
Blimey a week odd early, thanks for the heads up. :)
Why a week early? I would have said 2 weeks late? Thought they were keeping the .x as the month of the year for the release. So 6.6 should be the June release and at the start of 2006 they were out in the first week of the month every time. I'd expect 6.7 in 2 weeks at the most following convention, but not going to happen as it seems they are off track timewise.
Nick
Both May and June have been released in the last week (ish) rather than the normal first 2 weeks of the month.
They must be off track then, as they always release them in the first 2x weeks of every month as said above. :)
No problems here so far, and these are still inteferance free on TFT's, like the 6.5's. :)
They seem ok, but one thing i've noticed is that you cant quite clock the memory as far in the CCC as you could in previous versions.
*edit* Just to clarify, its simply the drivers that dont allow you to clock quite as high within CCC, i've no doubt that the card would still clock using another method. To be honest there is nothing in it, CCC used to allow 797 on the memory, now the max it allows is 792. The core remains at 689 as max in the CCC.
Been playing around with them now that they're official, and I can report that my X1800XT is a lot more stable at higher clocks with ATi Tool now. I might be able to push the core to 730MHz+ easily where I was getting artifacts at 725MHz before.
Úlfhednar said:
Been playing around with them now that they're official, and I can report that my X1800XT is a lot more stable at higher clocks with ATi Tool now. I might be able to push the core to 630MHz+ easily where I was getting artifacts at 625MHz before.
625Mhz is the X1800XT's default clock, if you were getting artifacts at that i'd suspect that your card may be dodgy. I assume you meant 725Mhz + :) looking at your sig.
Oops, typo. :o Thanks for spotting it. :)
Yeah, might be able to get 730+ easily, something I considered impossible only 24 hours ago on my card without fitting a water block on it. :eek:
Concorde Rules said:
Hmm, 3D video problem sorted?
Edit: that being setting 700/800 in ATi Tool and when a ingame video starts it goes to 500/600??
CR.
would be interested to know this one?
Will try it later myself when i get home but this was a hassle for me. Still not managed to get it sorted. :confused:
CR.
Did you disable the ATi processes that deal with 2D/3D clocks? Basically that leaves the card stuck in 2D clocks, and you up the voltage through ATi Tool and increase the clock frequencies to, and above, the 3D clocks.
Was reading on rage 3d that crossfire and dvi is broken with this driver release, have to use vga. back to 6.5 for me. :(
