ATI Client (beta) with updated (1.2.1) CAL DLLs
Man of Honour
30 Oct 2002
Surrey
From the Folding Forum thread here
VijayPande said:
Post by Vijay Pande on Tue Nov 11, 2008 4:30 pm
This is an open beta to test the new CAL DLLs and newer 4000 series cards (older cards, i.e. 36** card or below should not use this client). If this open beta looks good, we'll put it on the dowload page. Given the strong performance in closed beta testing, this move will likely come soon, unless somehow some new showstoppers come up.
The client supplied should work with all CAL capable ATI cards, please report if you find that a card isn't recognised (the client should accept any HD 4**0 card in addition to those previously supported). It will also work with NVIDIA cards, but the client is functionally identical to the current released version.
This client has a version number of 6.20r2beta and expires on 2nd March 2009 (it shouldn't stay in beta for this long however, as we are keen to get the updated CAL DLLs out to the masses sooner rather than later).
Systray Installer (XP or higher)
http://www.stanford.edu/group/pande.../[email protected]
Console zip file (XP/Server 2003)
http://www.stanford.edu/group/pandegroup/folding/release/Folding@home-Win32-GPU_XP-620r2beta.zip
Console zip file (Vista/Server 2008)
http://www.stanford.edu/group/pandegroup/folding/release/Folding@home-Win32-GPU_Vista-620r2beta.zip
I'm getting about a 50% ppd improvement, good stability and lower CPU useage on vista on my 4850. Still not 8800 performance but hey any increase is a good increase. :)
People in the thread report lower CPU usage on XP too which is great but some are having problems, not sure if they have tweaked it since then but I'm not seeing problems even though my card is Oc/ed.
YMMV of course.
I have a Crossfire 4850 set up, which i don't use for folding. The way i see it is that the ATI cards are not up to folding at the moment, power to PPD is not worth it. But maybe this new client will change my mind, also the next ATI drivers are ment to give folding users a little boost. But with both these things going on it might bridge that gap between ATI & Nvidia.
Tips if having stability issues:
  • If using Vista Force Windows XP (SP2) compatability mode on fah_core11.exe and [email protected]
  • Use -forceasm in advanced tab (additional client parameters)
Not sure what I may have missed, but after installing this client I'm getting the same PPD with my 4850 as previously...
FahMon says 2959.20 on project 4742. Although it seems to be having trouble getting a new WU since last night.
4850 is at stock.
Just installed this and haven't really seen a huge increase in PPD but CPU usage is down from 100% of one core to around 50% which is quite welcome.
I only have one 4870 running F@H with the other 3 cores doing S@H so the extra bit of free CPU is nice!
From what I can see Fahmon has said that I have gone from 2690PPD with the old DLLS and .exe to around 2848PPD.
This is with my 4870 at 850MHZ core and 950MHZ Memory...
Doesn't seem to good but only just installed Fahmon so will give it a while.
Will report back if there is any change!
EDIT: This is on Vista x64 btw. It has also completed one WU in 4hrs 10 mins. I'm now looking at around 2950PPD...
Berserker, the client seems pretty stable for me with my 4870. In fact the O/C I have atm (850MHZ Core) isn't really stable in games but seems fine with F@H :confused:
P.S. I also seem to be working on projects 5733 which give 511 points per WU... are these good?
Do both. I do rosetta on the CPU and FAH on the GPU, 1900PPD is nothing to be sniffed at and helps the team :)
Is its Vista or XP? If Vista its a no brainer as the GPU client uses single digit % CPU use. IF XP then you are looking at about 50% of one CPU.
I had to uninstall this beta to start receiving WU's again - no idea why. I've had a second go at running it and now, although it's running, I'm getting around 600 PPD less than before (according to FahMon, I've dropped from around 2.9k PPD to 2.3k PPD).
This is on a stock 4850 running on a Q6600 @ 7 x 400 with 4Gb RAM under Vista x64. The GPU client is assigned to 1 CPU core with the SMP client assigned to the remaining 3.
I'm guessing I'm doing something wrong, so any help to get my PPD back up would be appreciated, especially as I've temporarily lost the use of my Ubuntu box and the PPD that generates.
Remember different Work units have different PPD's All I can suggest is make sure that you have the XP compatible flag on both the F@H application and the core client as well. Then check you have -forceasm on in the client advanced settings.
Thanks for the tips. Yup, I remember that different WUs generate different PPD.
Tried your suggestions, no change...guess this is just the new status quo for now. Shame, though...
