ATI Control Panel.
5 Jul 2003
Atlanta, USA
Hi.
Ive just done a small upgrade to my system and in the process, i 'DriverCleaned' the old ATI stuff off and put the new drivers on.
The problem is, and this is quite a wierd one, that when Catalyst Control Center is on, if i change ANY setting in it, my 2nd display cuts out until i goto the windows display panel, lower the res, apply, raise the res, then apply.
And, more importently, Opera, iTunes, RegCleaner and a few other programs wont open. Their processes will display in the process list, but they wont actually display.
Once i removed CCC, everything was back to normal. Problem now is that i dont have a way to change the graphics options.
Is there a version of the 'old' ATI Control Panel around that i can use?
Thanks in advance all.
ACESHIGH said:
I believe they are in the NGO drivers.
Or you can use ATI tools / ATI tray tools.
Thanks. Ive installed TrayTools. :)
Its a pitty theres nothing thats intergrated into the main display control panel like the drivers of old. :(
