ATi de-interlacing
12 Feb 2004
Chesterfield
collegue at work has an Asus EAH3650 running Vista Media Centre. Having problems with de-interlacing keeps turning itself off though the tick-box says it's on. Have tried 8.10's and 8.11's with no change. Worked ok on his old x1550. Any ideas?
it's a fully fledged media center so I presume he wants to use the default MS player for tv etc.
Is this with in CCC ?
Avivo Video.
Basic Quality
Use automatic deinterlacing not ticked means its on but you must choose the method with the slider below.
But why he cant use the Auto i dont know.
Googled it ?
Hi, I'm the colleague zytok is talking about. Never had this problem before until I upgraded my gfx from an ATI X1550 -> ASUS ATI EAH3650 silent magic. It's very random one day it will be working perfectly, the next day de-interlacing is broke (as in it doesn't do any) and the PQ is terrible. Mess about with stuff and it somehow works again for a bit. Doesn't matter if on Auto or manually select setting on slider. Can't find any posts anywhere on subject, not sure if need to do a clean Vista Ultimate reinstall to clear out old hardware junk but don't want to go to the trouble only to find it isn't fixed ! Tried uninstalls, driver cleaner etc.
