Man of Honour
- 21 Nov 2004
So I recently bought a HD6990 and installed the latest ATI drivers (11.4s) and catalyst profiles. The problem, is that any drivers newer than the 10.4s cause the Sims 3 and Dead Space to lock up either before the main menu or during navigation of the main menu (sometimes even with a BSOD and having to manually shut off the PC).
- I had the same problem with my HD5970
- A fresh install of windows has not fixed the problem
- As far as I am aware all of my drivers are up-to-date
Based on the above I assume it is a problem with the ATI drivers. Anyone got any ideas? Was something added to the drivers around the time of the 10.4s?
Specs (and in sig):
Intel Q9550
Asus P5Q Deluxe motherboard
8Gb Ram
Asus D2X
HD6990
Would really appreciate help, as before I could get away with older drivers, now I can't.
My next thing to try is to disable one GPU in CCC. Might have to try diabling others things too?
Specs (and in sig):
Intel Q9550
8Gb Ram
Asus D2X
HD6990
