ATI - driver installation
8 Jul 2005
I am back to the red team after a 5 month defection to the greens. I need to know is it still possible to just load the drivers without the Catalyst Control Centre and if so are there any disadvantages. I am not concerned about having no saved game profiles - I enjoy the ritual of changing the settings each time before playing a different game.
navigate here
Drivers and Software > Windows XP > FireMV > FireMV 2400 PCI >
yes, strange i know ;)
Display Driver, Control Panel Download
1 of 1 22.0 03/09/06 1 package
Version: 6.3
Release Notes
Then download that, you may need to get the WDM and VIVO drivers off the normal download page too.
Tom
Yes you can... when you install, you get 2 options.. express and custom.. chosse custom, and untick control centre.. easiy as that!!!
However, you dont get any options to modify any settings, otheer than screen res and refressh rate etc... i dont think you even get the ati tray icon or control panel...
Above post not there when I was submitting... handy info.. thanks!!
your sig is way too big mate, 4 lines only.
Plus if you do it my way you get the original control panel. Someone on the forum found this jem.
