ATi driver problems.
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
Well I was on 10.1, reverted to 9.8.
On both of these drivers, I got a BSOD, before this the drivers where working correctly, but after the BSOD, ATi CCC fails to work.
I get this error message:
Catalyst Control Centre: Command Line Interface has stopped working.
Any ideas?
Thanks
Will.
Tried older drivers?
Edit: Close down any CCC/ATI processes and manually start CCC with right clicking "Run as Administrator". Might have to turn UAC off if you are running Vista, then turn it back on after. Worth a go
Err, he must have net installed because he had CCC working before he installed the 10.1 drivers and CCC requires net 2 at the minimum.
Doesn't seem to matter mate I've had it before when you update it just kicks back the CCC error, Re installing .Net sorted it for me & others.
One of those issues when there is No explanation but it works.
Latest version of .net? what is it? 3.1?
I ran driver sweeper, it appeared to even delete the default windows drivers, cause I uninstalled the 9.8's and it was like no driver installed. re installed em now, will see how it goes, if I get the error again I'll have to try uninstalling and re installing this .net.
