ATI drivers for X1900 XT??
14 Dec 2004
Bridgwater, Somerset
What version drivers does anyone use? The latest versions or a slightly older bunch?
Just curious as I was wondering if there are any great differences with performance across the drivers??
Many thanks :)
Yeah latest ones just add the odd game fix, and either give you a drop in 3D Marks, or a few points higher, still on the 6.9's here as i can't be bothered uninstalling them, and installing the 6.12's just to see which way my 3D Mark score goes up/down, not interested me.
Ill only upgrade when they add the new ALPHABLEND EATM feature, thought it might have been in the 6.12's but no, so ill see if it will appear in the 7's, if not i won't bother still, its normally only a couple of driver releases after a new card where they give a boost in performance, then every driver after that is just the odd game fix and a drop, or a higher score in 3D Marks as said. :)
Least if you use the 6.12's then you'll already have the performance boost from the previous sets that gave it, and be uptodate on the game fixes.
