ATI fan control by temp
27 Oct 2005
i know tray tools used to do this when i had my old old X850XT but i cant get it to work on win764, are there any other programs that allow you to set the fan speed at certain temps?
ta
Rivatuner is far the best program i have used to O/C GFX cards, just read up what you want to do, there's loads of helpful info if you look for it"!!
Rivatuner does it, but it's somewhat tricky to configure - you don't specify speeds according to temps you specify the min/max temps, min/max fan duty % together with other variables that determine how fast the fan reaches those settings. It can be a bit complicated.
Incidentally since Catalyst 9.8 the ATI drivers do auto-fan speeds based on temp themselves. I uninstalled Rivatuner (as I was only using it for this purpose anyway) and have not had any issues just letting CCC deal with it.
