Hi there.
Have just got a MSI 4850 1GB (factory overclocked version).
Have got some pretty decent benchmark scores with no overclocking on my system at all, but then thought I would try it out a bit.
All MSI drivers and catalyst control centre installed.
I used ATi overdrive to overclock. First started up overdrive with the Auto feature. Card got quite hot (up to 70deg) so I stopped it. Tried doing it manually, but whenever I activate the overdrive checkbox, I get a really annoying jumping vertical line thing on my second monitor. It is like the bottom half of the display is jumping up and down everytime i click the mouse. as soon as I unchek the Overdrive box, everything is back to normal. My main monitor is just fine....
ANY IDEAS CLEVER PEOPLE?
thanks
Doug
MY SYSYTEM:
Vista 32
4GB OCZ (2 x 1GB) 1066MHZ PC8500
Intel Core 2 Quad Q6600
BIOSTAR P43-A7 Socket 775 Intel P43 Moboard (not overclocked)
thanks
Doug
MY SYSYTEM:
Vista 32
g/l
