Hi, I currently own the above card and it runs great. However, i used to own the 6950 HIS, until the temperature sensor broke and put the fan on 100% all of the time, so i was sent a replacement. My big problem is, now that i have my new graphics card, Photoshop CS5 has sopped working altogether, there is no image displayed in the main area, and i cannot place a image there, or start up by going "open" etc... I managed to find a performance section where i was able to disable the use of my graphics card assisting photoshop, and then it all works fine, but as soon as i click anything other than paint brush, it crashes completely, and my pc is unable to close the application until i shut down. My PC specs are, AMD (something quad core, sorry for being less specific) 4GB ram, 6950 AFX, and Windows 7 64Bit (it ran on the old card with 64bit before you point that out
I have checked online for anyone else with this issue, but i cannon find anything, i have sent a similar message to adobe and awaiting a reply. So i was just wondering if anyone here had any ideas
Thanks for your time.
)I have checked online for anyone else with this issue, but i cannon find anything, i have sent a similar message to adobe and awaiting a reply. So i was just wondering if anyone here had any ideas
