- 25 Jan 2011
- Solihull, Birmingham
Hey, just a mini guide to get a stable overclock on a radeon 6970 or unlock 6950 as its basically the same card
Ok so from catalyst control centre we need to go to the AMD Overdrive section, where you will see (if you havn't looked at an overclock yet) a little lock picture of a padlock, you click this and it may ask you to confirm you want to unlock it and you accept there t's and c's about overclocking risk's etc etc, just click yes, its almost impossible to damage your card with CCC.
Now you should have 4 sliders available - each with a considerable power to change your card-
High performance GPU clock settings - the ability to change to core clock of your GPU
High performance Memory clock settings - the ability to change the clock speed of your memory
Power Control settings - in my opinion the most effective slider, the amount of power your card can utilize can dramatically effect your benchmark fps (ie furmark) by up to 60fps, in my experience
Fan control - no performance increase, noise increase
but also you need to access this or your card will hit 100c on a long bench and start to fry
To start overclocking from this point, choose one of the first two sliders gpu or memory clock, lets say we start with gpu clock - left click the slider and scroll your mouse wheel by 1 click - on my CCC this is a 15mhz increment, each click of the wheel, click apply, your screen might quickly flash - then run furmark or your normal benchmark at your normal settings and look for average fps improvements, also look for graphical defects, distorted pixels, bright colour blocks, clear blocking of picture in area's etc - You'll notice if your graphics go funny, if it goes too far the screen may go black as the driver attempts to recover, this is because the core gpu cannot keep up with clock speed you have requested from it and it loses sync, keep stepping up in these mousewheel turn increments until the picture starts to fail/lockup at your standard benchmark settings, then run it a few more times to check stability.
After this, drop that slider back down to default and repeat the process with the memory slider, looking for graphical abonormalities.
Doing the clock and memory seperately makes it easier to diagnose where a graphics crash/fault is coming from should one occur - this overclock can take a while, therefore PATIENCE is your ultimate virtue in being successful.
The voltage meter - the one slider which you can just whack up to max from my experience, it lets your overclocks really work hard but without the risk of a damaging voltage as its limited by CCC
From here you should test your overclock a few times on your favourite bench, furmark is most effective to see improvements in, you should notice at least 30fps improvement, also make sure your fan speed is set to manual control - i find 50% keeps the card around 60C on any bench, though the cooler it is, the longer your card will last, even though at 100% it does indeed sound like a hairdryer
Any questions guys, feel free to, also check out my phenom overclocking thread in the CPU section of this forum!
Jamie - XOUK
http://www.youtube.com/user/XtremeOverclockUK?feature=mhsn
My new youtube channel, what my overclocks have been able to render
Jamie - XOUK
so there are some out there.
