cool, does your card switch to 3d speeds if you run this windowed program? :
http://www.daionet.gr.jp/~masa/rthdribl/
rthdribl
rthdribl
a 30MB hotfix? Do I install it on top of 8.1 or instead of 8.1?
rthdribl
hmm, wonder why they can;t fix that problem for x1900xt users?
just read this review here: http://www.firingsquad.com/hardware/sapphire_radeon_hd_3850_ultimate_3870_atomic/page11.asp
3870 gets slapped up by a 8800gt in every test by a large margin. have to wait for the cost of a 8800gt to come down. and gonna wait for the 9600gt to make its appearance.
running 3Dmark at stock on a 3850 I get 100 points more than when using 7.12. BUT!! when using ccc overclocking card to 720/950 I get 200 points less :s.
Any idea what the bejesus is going on there anyone?? bit puzzled. Btw temps are fine under 80c.
SHAKES FIST AT MARC
Didnt notice that before... CANT TAKE MY EYES OFF IT NOW. WTF?
EDIT:
Only appears when other Windows are open.
If you click "Show Desktop" or "Windows+D" it goes away.
hmm, i heard that if you overclock over the cards limit it actually lowers the score. i had the same problem with my x1950gt, at 580/1300 (defaults 500/1200) i scored less than the defaults.
http://www.firingsquad.com/hardware/sapphire_radeon_hd_3850_ultimate_3870_atomic/page8.asp
here is the other benchmark page, i knew the 8800gt was quicker than the 3870, but i did not know it was so far ahead in terms of speed. may well be worth the 150 quid for a 8800gt insted of the 130 quid for a 3870.
but will wait for the 9600gt and see how things progress.
i bet you gurusans 3850 beats any 8800GT score on 3dmark 06 from this forum and the 3850 can be had for less than £100, and his overclock can be achieved by following a few simple steps
What a pasting.
The X2 might not be much of an increase over 1x GT if you think about it then, as its gota add all those frames back to 1x 3870 to match the GT, then add more to beat it.
Take Crysis there for instance, the 3870 is over 12fps slower, so that means the 2nd one on the X2 has to add those frames just to match the GT, then its gota add more on top to beat it.
